Hello experts,
my cursor disappears when the space bar is pressed and then reappears in another place, uncontrollable. Moving the cursor with the mouse does not work properly either. Googling unsuccessful.
Are you smarter?
Maria
Hello experts,
Are you smarter?
Maria
Hello
Have you already checked the mouse properties (pointer options) to see if everything is OK there?
Hello Blue,
everything seems to be OK with the mouse. At least from my amateur point of view. Except in Word, it works perfectly. Or are there any special settings?
Greeting
Maria
In the Mouse properties, under Pointer Options >> Visibility, you have the option of: Hide pointer on keyboard input.
Uncheck there and try again.
I did. Nevertheless, if you press the spacebar, it disappears and reappears somewhere.
Greeting
Maria
Hello
PC or notebook?
There are in the settings under Hardware >> Properties >> driver the possibility to update it.
Please try again too.
PC, I'll try the driver thing now.
It's not the driver either.
See if you can update Word.
My (Office) Word has all available updates.
Hmmm,
you could still try to test the mouse on a different USB port.
I've done it already. Unsuccessful.
Hmmm ....
In the Mouse settings under Pointer options, what does the setting under Movement look like?
The controller should be in the middle.
But you can experiment with it a little.
So pull something slowly and test again.
Otherwise I'm running out of ideas, unfortunately ...
Didn't bring anything either. But other forums have also found their teeth hard on this problem. For years. No reaction from MS!
Thank you for your help.
Maria
Another thing Blue - when I call "Outline / Outline view" everything works fine again.
Hello justice,
found some posts. I don't have a NB myself and couldn't understand it ...
But read for yourself ...... there may be a tip here
Cursor jumps to Word (tina2907) (Page 2) - Computerhilfe.de
Cursor jumps uncontrollably in Word Text - WinBoard - The Windows Community
Hello Helloween,
unfortunately there was nothing to solve the problem.
Thank you!
Maria
