Ping wechselt ständing zwischen 50 und 120
  • f1337zor
  • 11. Januar 2006 um 22:28
  • cut_throat
    Profi
    • 17. Januar 2006 um 11:42
    • #21
    EDIT: \\Steam\SteamApps\deinName\Counter-Strike\cstrike_german
    das ist der Pfad bei der deutschen version :D
    ASUS G1
    Vista Home Premium
  • f1337zor
    • 17. Januar 2006 um 13:34
    • #22
    danke danke aber das prob hat sich schon gelöst, hab mal den ccleaner drüberlaufen lassen dann ging das wieder
  • f1337zor
    • 19. Januar 2006 um 21:17
    • #23
    also ich hab hier mal meine config
    // This file is overwritten whenever you change your user settings in the game.
    // Add custom configurations to the file "userconfig.cfg".
    unbindall
    bind "TAB" "+showscores"
    bind "ENTER" "+attack"
    bind "ESCAPE" "cancelselect"
    bind "SPACE" "+jump"
    bind "'" "+moveup"
    bind "+" "sizeup"
    bind "," "buyammo1"
    bind "-" "sizedown"
    bind "." "buyammo2"
    bind "/" "+movedown"
    bind "0" "slot10"
    bind "1" "slot1"
    bind "2" "slot2"
    bind "3" "slot3"
    bind "4" "slot4"
    bind "5" "slot5"
    bind "6" "slot6"
    bind "7" "slot7"
    bind "8" "slot8"
    bind "9" "slot9"
    bind ";" "+mlook"
    bind "=" "sizeup"
    bind "[' 'invprev'
    bind ']" "invnext"
    bind "`" "toggleconsole"
    bind "a" "+moveleft"
    bind "b" "buy"
    bind "c" "radio3"
    bind "d" "+moveright"
    bind "e" "+use"
    bind "f" "impulse 100"
    bind "g" "drop"
    bind "h" "+commandmenu"
    bind "i" "showbriefing"
    bind "j" "cheer"
    bind "k" "+voicerecord"
    bind "l" "say ONKELZ STERBEN NIE!!! Vaya con tioz"
    bind "m" "chooseteam"
    bind "n" "nightvision"
    bind "o" "buyequip"
    bind "q" "lastinv"
    bind "r" "+reload"
    bind "s" "+back"
    bind "t" "say thetime"
    bind "u" "messagemode2"
    bind "v" "+voicerecord"
    bind "w" "+forward"
    bind "x" "radio2"
    bind "y" "messagemode"
    bind "z" "radio1"
    bind "~" "toggleconsole"
    bind "UPARROW" "+forward"
    bind "DOWNARROW" "+back"
    bind "LEFTARROW" "+left"
    bind "RIGHTARROW" "+right"
    bind "ALT" "+strafe"
    bind "CTRL" "+duck"
    bind "SHIFT" "+speed"
    bind "F1" "restock"
    bind "F2" "trouted_awp"
    bind "F5" "snapshot"
    bind "F6" "save quick"
    bind "F7" "load quick"
    bind "F8" "m4a1_ak47"
    bind "F9" "trouted_deagle"
    bind "F10" "quit prompt"
    bind "INS" "+klook"
    bind "PGDN" "+lookdown"
    bind "PGUP" "+lookup"
    bind "END" "centerview"
    bind "MWHEELDOWN" "invnext"
    bind "MWHEELUP" "invprev"
    bind "MOUSE1" "+attack"
    bind "MOUSE2" "+attack2"
    bind "MOUSE3" "wcteleport"
    bind "PAUSE" "pause"
    _cl_autowepswitch "1"
    _snd_mixahead "0.1"
    ati_npatch "1.0"
    ati_subdiv "2.0"
    bgmvolume "1.000000"
    bottomcolor "6"
    brightness "1"
    cl_allowdownload "1"
    cl_allowupload "1"
    cl_backspeed "400"
    cl_cmdbackup "2"
    cl_cmdrate "30"
    cl_corpsestay "600.000000"
    cl_crosshair_color "50 250 50"
    cl_crosshair_size "small"
    cl_crosshair_translucent "1"
    cl_dlmax "80"
    cl_download_ingame "1"
    cl_dynamiccrosshair "1"
    cl_forwardspeed "400"
    cl_himodels "0"
    cl_idealpitchscale "0.8"
    cl_lc "1"
    cl_logocolor "#Valve_Orange"
    cl_logofile "lambda"
    cl_lw "1"
    cl_minmodels "0"
    cl_radartype "0"
    cl_righthand "1"
    cl_shadows "1"
    cl_timeout "35"
    cl_updaterate "80"
    cl_vsmoothing "0.05"
    cl_weather "1"
    con_color "255 180 30"
    console "1"
    crosshair "1"
    fastsprites "0"
    fps_max "72.0"
    fps_modem "0"
    gamma "3"
    gl_dither "1"
    gl_flipmatrix "0"
    gl_fog "1"
    gl_monolights "0"
    gl_overbright "0"
    gl_polyoffset "0.1"
    hisound "1"
    hpk_maxsize "4"
    hud_capturemouse "1"
    hud_centerid "0"
    hud_draw "1"
    hud_fastswitch "1"
    hud_saytext_internal "1"
    hud_takesshots "0"
    joystick "0"
    lookspring "0.000000"
    lookstrafe "0.000000"
    m_filter "0"
    m_forward "1"
    m_pitch "0.022"
    m_side "0.8"
    m_yaw "0.022"
    model "gordon"
    MP3FadeTime "2.0"
    MP3Volume "0"
    mp_decals "300.000000"
    name "<=ApG=>%f1337zor"
    net_graph "0"
    net_graphpos "1"
    net_scale "5"
    r_bmodelhighfrac "5.0"
    r_detailtextures "0"
    s_a3d "0.0"
    s_automax_distance "30"
    s_automin_distance "2"
    s_bloat "2.0"
    s_distance "60"
    s_doppler "0.0"
    s_eax "0.0"
    s_leafnum "0"
    s_max_distance "1000"
    s_min_distance "5"
    s_numpolys "200"
    s_polykeep "1000000000"
    s_polysize "10000000"
    s_refdelay "4"
    s_refgain "0.4"
    s_rolloff "1.0"
    s_verbwet "0.25"
    sensitivity "1.5"
    skin ""
    spec_autodirector_internal "1"
    spec_drawcone_internal "1"
    spec_drawnames_internal "1"
    spec_drawstatus_internal "1"
    spec_mode_internal "4"
    spec_pip "0"
    suitvolume "0.250000"
    sv_aim "0"
    sv_voiceenable "1"
    team ""
    topcolor "30"
    viewsize "110"
    voice_enable "1"
    voice_forcemicrecord "1"
    voice_modenable "1"
    voice_scale "0.750000"
    volume "0.260000"
    setinfo "_vgui_menus" "1"
    setinfo "_ah" "1"
    +mlook
    +jlook
    exec userconfig.cfg
    hoffentlich hilft das weiter, denn ich werde noch verrückt mit diesem ping
  • f1337zor
    • 24. Januar 2006 um 21:07
    • #24
    HAAAAALLLLOOOOOOOO??????
    Kann mir da keiner helfen???
  • f1337zor
    • 24. Januar 2006 um 21:23
    • #25
    Antwort von 194.25.134.153: Bytes=32 Zeit=119ms TTL=250
    Antwort von 194.25.134.153: Bytes=32 Zeit=114ms TTL=250
    Antwort von 194.25.134.153: Bytes=32 Zeit=97ms TTL=250
    Antwort von 194.25.134.153: Bytes=32 Zeit=58ms TTL=249
    Ping-Statistik für 194.25.134.153:
    Pakete: Gesendet = 4, Empfangen = 4, Verloren = 0 (0% Verlust),
    Ca. Zeitangaben in Millisek.:
    Minimum = 58ms, Maximum = 119ms, Mittelwert = 97ms
    ich hab das mal getestet, das kann doch eigentlich gar net sein!
    Wie geht das das der so heftig hin und her schwankt?
    Bitte um Antwort weil ich hier bald verzweifle!
