XP Remote Desktop fails after installing ZoneAlarm
  • 8. August 2003 um 02:19
    Bitte entschuldingen meine Frage auf English, aber meine Deutsch is nicht gut genug fuer technishe Sachen.
    I have installed ZoneAlarm on an XP machine and now cannot connect over VPN to the XP machine, using the Remote Desktop Client on my Win2000 machine.
    Any idea if I should unblock an IP or the Remote Desktop Service, or something else?
    • 5. September 2003 um 03:54
    Ist irgendwie klar
    deine Firewall blockt diesen Port.
    Also einfach Port freigeben und dann sollte es gehen
    cu NeD
  • TheMatrix
    • 5. September 2003 um 08:01
    I think you need Zone Alarm Pro to unlock or lock individual Ports.
    The free Zone Alarm Version can´t do that.
    Other solution is, try another Firewall System (Kerio for example).
    Hope that helps
    Cheers
    TheMatrix
